| HCB concrete | 06-19-2026 | comment profile send pm notify |
I still run a 1993 Putzmiester boom with the smaller swelling cylinders nest truck over the past 10 years that I’ve run it or owned it as through a flowing through a rod out of the swinging cylinder half a dozen times currently is New suing Leighbere all new cups were installed new S2 and we checked the shams to make sure everything lined up good when we put it back together a week ago, three jobs later it’s thrown the slewing cylinder roof again. What do we need to do to stop this? |
| Todd | 06-26-2026 | reply profile send pm notify |
From what you’re describing (’93 Putzmeister, smaller slewing cylinders, repeatedly blowing the rod / slewing cylinder), there are a few critical areas to look at. Replacing seals, cups, S-tube, and shimming correctly is good—but if it’s still failing after only a few jobs, something upstream is overstressing that cylinder. Below is a structured checklist you can work through with your mechanic: 1. Check Pump / Truck Level and Set‑upOn older booms especially, being out of level is a big killer of slewing systems.
What to do:
2. Boom Handling / Operator TechniqueThe text you’re effectively running into is this reality: sloppy boom handling destroys slewing gear and cylinders. Things that are hard on the slewing system:
What to do:
3. Mechanical Alignment of Slewing AssemblyYou’ve checked shims, which is good, but with repeated failures you should verify the entire slewing system as a unit:
Any misalignment that forces the cylinder to work at an angle will dramatically increase side loads and blow seals/rods. 4. Hydraulic Pressure & Relief SettingsIf the slew circuit pressure or relief valve is set too high, the cylinder can be over‑pressurized:
A pressure gauge on the slewing circuit during operation can show if you’re spiking beyond spec each time you start/stop the boom. 5. Internal Cylinder Issues / Parts QualityYou said:
Also confirm:
If you’re using aftermarket components, consider going back to OEM or a verified high‑quality supplier for the slewing cylinder or kit. 6. Check the Slewing Cylinder Parts & Service InfoThe slewing cylinder for Schwing is often referenced like:
(These part numbers are Schwing examples, but the idea is the same: make sure you’re using the exact, correct kit and associated hardware for your Putzmeister.) If you haven’t already, it’s worth talking with a Putzmeister service tech or a specialist parts house and giving them:
So they can verify you truly have the correct cylinder and internals for that turret. 7. Practical Next Step for YouGiven that you’ve:
…yet it failed again after three pours, I’d do this in order:
If you can share:
I can help narrow this down further for you. |
